Symmetric Power Supplies
This simple ±12V or ±15V symmetric power supply is ideal for small electronics projects and low-power circuits.
It uses 78XX and 79XX series voltage regulators, capable of delivering up to 1A with proper heatsinking. The design also includes 1N4001 diodes for rectification and 1000µF capacitors for smoothing the DC output.
Key Features:
  • Output: ±12V DC or ±15V, up to 1A
  • Regulators: 78XX (positive) and 79XX (negative)
  • Rectification: 1N4001 diodes
  • Filtering: 1000µF capacitors
  • Applications: Low-power symmetric circuits, audio preamps, op-amp projects
Tip: Always use adequate heatsinks for the 78XX/79XX ICs to prevent thermal shutdown, and ensure the capacitors are rated above the maximum voltage.
IC from 78XX and 79XX series can draw 1A max with heaththink.
12V Symmetric Power Supply
Symmetric Power supply 12 Volt
15V Symmetric Power Supply
Symmetric Power supply 15 Volt
Pcb and Components Layout
PCB for symmetric psu with 78xx and 79xx series
components layout
