12V Car Battery Level Indicator (LED)
This simple LED battery level indicator monitors a 12V car battery using a minimal component design.
The circuit uses two resistors (680Ω and 1.2kΩ) and two Zener diodes (10V and 13V) to define voltage thresholds. A red LED lights up when the battery voltage is low, and a green LED lights up when the voltage is within a safe range.
Key Features:
- Input Voltage: 12V DC
- Indicators: Red LED (low voltage), Green LED (safe voltage)
- Components: 2 resistors, 2 Zener diodes, 2 LEDs
- Purpose: Quick visual check of battery charge status
Tip: Adjust the Zener diodes’ voltage values to match your battery type or desired warning thresholds.
Led battery level indicator
