Vu Meter LM324
This audio VU meter uses the LM324 operational amplifier to drive a series of LEDs, providing a visual indication of audio signal levels. The circuit can be adapted for multiple LEDs to form a thermometer-style display.
The LM324 amplifies and processes the audio input signal, converting its amplitude into a voltage level that drives the LEDs. As the input signal increases, more LEDs light up, creating a moving light bar to indicate the instantaneous audio amplitude.
  • Displays audio signal amplitude using multiple LEDs
  • Thermometer-style LED display for intuitive visualization
  • Uses the LM324 quad op-amp IC
  • Input signal can be adjusted via a potentiometer for calibration
  • Flexible design suitable for desktop or DIY audio projects
  • Use LEDs with similar brightness for uniform display.
  • Include current-limiting resistors for each LED as per design calculations.
  • Keep audio input wiring short and shielded to minimize noise.
  • Use a suitable supply voltage for the LM324, typically 9V to 12V DC.
  • Ensure the op-amp is mounted on a PCB with proper decoupling capacitors close to the IC.
Vu meter
