Touch Alarm Circuit
This circuit uses a touch sensor to trigger an alarm through a 555 timer and a transistor–relay driver stage.
When a signal is received from the touch sensor, the 555 timer generates a short output pulse. This pulse drives a transistor, which in turn activates a relay (RELE) connected to the alarm or any external load.
The system provides a simple and reliable way to detect human touch and can be used for security alarms, door entry systems, or interactive projects.
Touch Alarm Schematic
touch alarm PCB
Components
  • R1-100K
  • R2-4K7
  • R3-10M
  • R4- *SEE NOTE
  • R5- *SEE NOTE
  • P1-100K
  • D1-1N4148
  • LED1-LED2 - 3mm
  • C1-47uF
  • IC1-555
  • T1-2N2222 or 2N3904
  • RELE 6V-12V
*Note: If voltage=9V R4-390 R5-390, If voltage=12V R4-1K R5-1K
